The result of the packaging process using the Packager for Linux and UNIX is called a PIF product.
On the Packager GUI, several tools and wizards support you to create new products or copy and modify existing products.
You can also easily create or modify PIF products from the Software Management command line interface (CLI). Once you have created a prototype file, you can modify it using an editor, or duplicate the prototype file, modify the duplicate, and run the pifmk command to build a new PIF product from the modified prototype file.
PIF products can be created for and installed on all Linux and UNIX operating environments that are supported by the PIF SDK.
