Values for PIF product parameters can be provided in different ways, as follows:
The default value of a parameter is defined in the Default section of the prototype file. The default value ensures that a value always exists for that specific parameter.
During product installation, the Installer examines the environment of the running shell. If a parameter value has been assigned on the shell, it will overwrite the default parameter value defined in the product.
A response file, which is provided by the user to configure an unattended product installation, contains parameter value assignments that overwrite the default parameter values defined in the product.
You can define parameter value assignments in pre-install scripts (scripting parameters). These scripts insert the parameter values in the product when they are run during the product installation process.
