Previous Topic: Execute a Migration ScriptNext Topic: Run Post-Interview Script
Run Installation Dialogs
The Installer runs the installation dialogs defined for the PIF product. From these dialogs, the Installer gets the parameter values to configure the installation of the PIF product.
When the target computer has the Java Runtime Environment (JRE) 1.5 or 1.6 installed, and the monitor is graphics-enabled, the installation dialogs appear in the graphical mode (Java GUI). If these prerequisites are not met on the target computer, the installation dialogs appear in a VT100 compatible mode.
You can include a JRE in a self-installing PIF product, that will then install and use the included JRE to run the Java wizard of the Installer on the target computer.
