Using Packager and Installer for Linux and UNIX › Product Parameters › How the Installer Resolves Parameters
Parameters used in a PIF product are resolved by the Installer during installation of the product on the target computer. Following are the steps the Installer performs, depending on the type of installation.
- New installation
- Reads default parameter values defined in the PIF product.
- Reads parameter values from a response file.
- Reads parameter values from an installation dialog (installation path can be modified).
- Reads parameter values from the existing environment (unattended mode).
- Reads parameter values changed after execution of the product-specific pre-install script.
- Reinstallation
Reads parameter values from the previous installation (installation path cannot be updated).
- Update installation
- Reads parameter values from the previous installation.
- Reads parameter values from an installation dialog (installation path cannot be updated).
