Each parameter used in the PIF product has to be assigned a default value; otherwise, the product creation will fail. These default values are used for the following purposes:
In the prototype file, you define default values for parameters in the @DEFAULT section using the keyword #parameter.
Important! When you create a PIF product using one of the standard product templates, default values are already assigned automatically to the parameters.
