Previous Topic: lsm—Manage Software Installations on Linux and UNIX SystemsNext Topic: Supported Linux and UNIX Operating Environments
Install a Self-Installing PIF Product
A self-installing PIF product is executed as a shell script. The command options specify how to install the PIF product on the target computer or that only a response file is created.
sh selfinstallingfile [-t tracefile] [-p logfile] [-r responsefile]
[-s] [-F] [-x] [-a newresponsefile] [-v] [-I instance name] [-V] [-o] [-M textID]
selfinstallingfile
Name of the self-installing PIF product, as defined, for example, through the pifself command.
-t tracefile
Traces the installation in the specified trace file.
-p logfile
Logs the installation in the specified log file.
-r responsefile
Installs the product using the specified response file.
-s
Installs the product in unattended (silent) mode using default parameter values.
-F
Forces the product installation. Backup errors are ignored.
-x
Only extracts the product to the /tmp directory. The file name used for the extracted product is internally defined and echoed to the command line.
-a newresponsefile
Creates only a response file with the specified name. This response file can be used for a later installation of the PIF product.
-v
Lists the version of the installer included.
-I instance name
Specifies the name of a new product instance (for multi instance installation).
-V
Enforces VT100 dialogs.
-o
Overwrites existing response during response file generation (-a).
-M textID1[-textID2] -f prototypefile
Refers to a single text (specified by textID1) or a range of texts (specified by textID1-textID2) in the resource section of the specified PIF product prototype file. Each script of a PIF product can use this command option in order to print localized texts.
Example: Execute a self-installing PIF product and record trace information
The following command executes the self-installing PIF product test-pif.AIX.sh and installs the corresponding PIF product in unattended (silent) mode. Trace information is written to the specified trace file test-pif.AIX_tracef in the mytemp folder:
sh test-pif.AIX.sh -s -t /mytemp/test-pif.AIX_tracef
