Symptom:
I install the Installer using a self-installing PIF product. Which directories does the Installer use or create on the customer system?
Solution:
The Installer stores its files in the $CASHCOMP/installer directory. This directory will be either created or updated on the customer system.
The program lsm is added to /usr/bin.
A link is created from /opt/CA/installer to $CASHCOMP/installer.
