Previous Topic: Packager InstallationNext Topic: Packager and Installer Installation Folders
Packager Installation Program
The Packager installation program install-sm-packager.sh is a self-installing PIF product. You can specify options when executing install-sm-packager.
The command has the following format:
sh install-sm-packager.sh [-t tracefile] [-p logfile] [-r responsefile] [-s] [-F] [-x]
-t tracefile
Traces the installation in the specified trace file.
-p logfile
Logs the installation in the specified log file.
-r responsefile
Installs the product using the specified response file.
-s
Installs the product in unattended (silent) mode using default parameter values.
-F
Forces the product installation. Backup errors are ignored.
-x
Only extracts the product to the /tmp directory. The file name used for the extracted product is internally defined and echoed to the command line.
-V vt100 mode
Installs the product in a character-oriented VT100 mode.
-a ask mode
Installs the product in the Ask mode.
-o overwrite (response file)
Overwrites existing response during response file generation.
