Symptom:
The DHCP server is not providing the boot server information.
Solution:
This happens if your boot server is not located on the DHCP server.
With PXE 2.x clients, you can assign a different boot server using the DHCP option 43 (encapsulated vendor-specific options). The DHCP server must be configured to provide additional boot server information in the DHCP offer using option 60 and option 43:
After the PXE client has received an IP address from the DHCP server, the PXE client must send a DHCP Request to the specified boot server (in option 43:Suboption 8: PXE boot servers) to get the boot image file name.
Example: DHCP Offer
Option 53: DHCP Message Type = DHCP Offer
Option 54: Server Identifier = 192.168.111.131
Option 60: Vendor class identifier = "PXEClient"
Option 97: UUID/GUID-based Client Identifier (17 bytes)
Option 43: Vendor-Specific Information (PXEClient)
Suboption 6: PXE discovery control = 2
Suboption 8: PXE boot servers (7 bytes)
Suboption 9: PXE boot menu (38 bytes)
Suboption 10: PXE menu prompt (24 bytes)
Suboption 71: PXE boot item (4 bytes)
End PXEClient option
End Option
option 43 in detail:
2b 55 06 01 02 08 07 00 07 01 c0 a8 6f 83 09 +U..........o..
26 00 07 23 43 41 2d 55 6e 69 63 65 6e 74 65 72 &..#CA-Unicenter
20 4d 61 6e 61 67 65 64 50 43 20 42 6f 6f 74 20 ManagedPC Boot
53 65 72 76 65 72 00 0a 18 00 50 72 65 73 73 20 Server....Press
46 38 20 74 6f 20 76 69 65 77 20 6d 65 6e 75 00 F8 to view menu.
2e 47 04 00 08 00 00 ff .G......
In the above example, c0 a8 6f 83 is the IP address of the OSIM boot server.
Notes:
To add DHCP option 60 to DHCP server (Windows 2000 or later)
A command prompt with the title dhcp server appears.
add optiondef 60 PXEClient STRING 0 comment=option added
optionvalue 60 STRING PXEClient
show optionvalue all
