CDs or DVDs
CreateOSImage -I <name> -o <REDHATES50(x64)-CD or REDHATES50(x64)-DVD> -a <NFS share name>
CreateOSImage -I <name> -o <SUSE102(x64)-CD or SUSE102(x64)-DVD -a <NFS share name>
Specifies the name for the external NFS share.
The command reads the setup files from CD1 or DVD1 and stores the files on the Image Prepare System / Boot Server.
Directory Structure
CreateOSImage -I <name> -o <REDHATES50-CD or REDHATES50-DVD> -s < distribution files path> -a <NFS share name>
Specifies the path to the directory that includes at least the directory images\pxeboot\.discinfo and the rpm package Server\syslinux*.rpm from CD1 or DVD1.
CreateOSImage -I <name> -o <SUSE102(x64)-CD or SUSE102(x64)-DVD> -s < distribution files path> -a <NFS share name>
Specifies the path to the directory that includes at least the setup files boot\* and the rpm package suse\i586\syslinux*.rpm (for 32-bit) or suse\x86_64\syslinux*.rpm (for 64-bit) from CD1 or DVD1. For more information about the folder structure, see Merging the Files from SUSE CDs or DVDs.
Note: If you do not provide the syslinux*.rpm package, you must add syslinux.com later. For more information, see the section Adding Syslinux.com to the OSIM image.
