OSIM installs RedHat and SUSE OS images by using the Kickstart or AutoYaST installation methods. The auto answer files, provided by OSIM, are available as templates for frequently used installations. You can use OS installation parameters to customize the auto answer files to suit your requirements.
OSIM also has post procedures to configure the target installations and to install the DSM agent. You can use the OS installation parameters in the post procedures as well. This makes it possible to use only one OSIM image for a variety of installations.
