Previous Topic: responsefile=Next Topic: file1=
partition=
Specifies the file that defines the partitions of the hard disk.
[parameterfile]
Identifies the files that contain OS installation parameters. If you have defined the parameters in some other files, you must add the path to those files under this section.
When the RegisterOSImage command executes, it searches the given files for additional parameter definitions, adds the parameters found to the default.ini file, and registers them with the OS installation manager.
If a parameter already exists in the default.ini file, RegisterOSImage tries to register the parameter using the following command:
Registerosimage -i <image name> -t
The new parameters get a default definition in default.ini; you can however, modify them by editing the default.ini file. If you have edited the default.ini file, execute the following command to add or update the parameter definitions to the MDB:
Registerosimage -i <image name> -s <manager> -b  [-e]
