Previous Topic: createzip=<name of the zip file>Next Topic: batfilename=
default=
This parameter refers to the default file that describes the operating system parameters. This file is normally called default.ini and is located at the share specified by the sharename.
[camenu]
The camenu section specifies files that control the OS installation process of this OS image. The files are all located at MANAGEDPC\CAMENU relative to the installation directory of the Boot Server / IPS image store.
