Previous Topic: Prepare and Capture ImageX or Ghost Images (Step3)Next Topic: Create OSIM Install Jobs to Prepare an Image (Step 3a)
Install the Model Computer
Your model computer can be installed from CD, DVD, or using OSIM.
Note: Do not install any CA agents, because this is part of the OSIM ImageX installation.
If you install the model computer using OSIM, set the OSIM job parameter
installAgent=no
BitLocker=no
