To create a support image of the GETIMAGE type use the IPS commands with the following parameters:
createosimage -i <imagename> -o <support_OS_type> [-g <imgtools>]
If you want to use only ImageX to capture a model computer and Microsoft Windows AIK is installed on the IPS, you do not have to provide the -g option. The ImageX files will be copied automatically into the GETIMAGE-structure. If you want to use Ghost32 as the imaging tool, you have to provide the -g option with the path to ghost32.exe client program.
To register the support image, use the following command:
registerosimage -b -i <imagename> OS -s <manager>
