OSIM Images Using ImageX and Ghost32 › Steps to Create an ImageX OSIM OS Image Manually Using a WinPE Boot CD › Create an Image Prepare System (IPS) Share to Write the Image Files to the IPS
To create an Image Prepare System (IPS) Share to Write the Image Files to the IPS:
- Create Write-enabled share, for example, “imgshare” on the IPS.
This share can be used for imaging of all targets and image types (ImageX, Ghost).
- Create for each template target a directory with the name of the target, for example,
mkdir \\imgshare\mytarget
If you plan to capture and hold more than one image from one target, create subdirectories for every single image.
- Copy the ImageX or Ghost.exe (32bit version) and its files into the directory that will hold the image file
(<name>.wim or <name>.gho)
