Valid on win32
The sdmpcimg.exe command provides options for the WinPE image support. These options include the following:
sdmpcimg [-m tftp] -[lptvz] ...
Get binl information about local interfaces and boot server.
Download parameter file found in binl packet from boot server:
-p [file/directory to download parameters to] [server ip] [server port]
Note: If [file/directory to download parameters to] is not provided, then the parameter file is downloaded to the current directory.
Get a file from the tftp server:
-t <file to download> [local file/directory to download to] [server ip] [server port]
Print version information.
Download caz file from server:
-z <caz file to download> [directory to download to] [server ip] [server port]
If [file/directory to download to] is not provided, then the file is downloaded to current directory.
If [server ip] is not provided, the IP address from the binl packet is used.
If [server port] is not provided, a connection is made to the default tftp port.
