Use the preplace.exe command to substitute OSIM parameters in text mode files. This command also applies to WinPE images.
Note: There are different versions for win32 and amd64.
preplace -i parameter_file1 [ ... -i parameter_filen] file1 [... filem]
where:
Specifies a list of files containing the OSIM parameters. The list elements are separated by spaces.
Specifies a list of files in which the parameters should be substituted. The files in the list are separated by spaces. In all files listed, each parameter value of $parametername$ is replaced with the value from the file parameter_file.
