To start an installation, you must restart the target computer. If a computer cannot be restarted, you can force a restart with the OS Installation option.
If Logoff User and Reboot is selected, the target computer starts a logoff and restart procedure at the given activation time. It is the installed agent which starts the target computer.
If a user is logged on to the target computer, the agent will raise a message and a five-minute countdown starts.
Each time the user clicks the Postpone button, the countdown restarts with a duration of 30 minutes.
