Previous Topic: Unsigned Drivers Support for WindowsNext Topic: OS ImageX Support
Boot Image Support
The boot image templates of WinPE30x64 and WinPE40x64 are extended to support unsigned drivers while creating the corresponding boot images. If you are upgrading, you can include any unsigned drivers in the existing boot images using Update Boot Image wizard from the IPS UI. You can also include the unsigned drivers using command line interface.
Note: The 32 bit boot images do not need any additional changes for supporting unsigned drivers.
