Symptom:
The installation of a new operating system starts immediately. This behavior is not desired in some cases.
Solution:
With the alternative DOS boot loader bootdos.f12, the user in front of the target can press CTL F12 within a 4-second time frame to start the OS installation.
Otherwise, bootdos.f12 will boot from the local hard disk and the OS installation job is postponed to the reboot when pressing CTL F12.
To use the bootdos.f12 in a sequence of reboots during an OS installation, the first boot image osinstal.2 has to be changed into an indirect boot image with its own loader.
To change the boot image osinstal.2 into an indirect image
Contents of the osinstal.2 description file:
[BootImage] Boottype=DOS BootImageDir=osinstal.2 BootLoader=bootdos.f12 SwitchFile=osinstal.2
Images:
DOSBOOT //Boot image store
UNDI //RAM disk image files DOS, WINPE, LINUX
osinstal.2 //description file
ostinstal.3 //real 1.44 Mb DOS floppy image
osinstal.2
bootdos.f12
undi
/osinstal.2 //real 1.44 Mb DOS floppy image
