This decodDat command creates a parameter file with localized parameter values. It searches the input files for parameters with names that end with "_UTF8$". When found, their values are converted to the given locale. "_UTF8" is removed from their names and the resulting parameter is written to the output file. Non-convertible characters are replaced by "?".
Note: There are different versions for win32 and amd64.
decoddat [-v] [-l locale] [-d charmaps_directory] [-u] -o output_file input_file
If present, the copyright and version information is written to stdout.
Name of the locale.
Default: ENU
Name of the charmaps directory.
Default: CAWIN
If present, a parameter $OSPasswdUxSV$ is generated from $OSPasswd$.
Name of the output file and the input file.
Example
decodDat -l ENU -d m:\DOSmaps -o c:\canpcloc.dat c:canpcext.dat
