The following parameters must be set to allow the boot server to communicate with ADS:
Must be set to 1, or true.
The IP address or host name of the machine that contains the MicrosoftADS namespace.
The ID of the user, who must be a member of the Administrators group on the ADS Controller and must have been granted full permissions to the \\ADSProvider\ROOT\MicrosftADS namespace.
If the user is not the “Administrator,” then a new user's access rights can be set by following these procedures:
Thw WMI Control Properties dialog appears as shown in the following screenshot:
The password to log in to the ADS controller for the given ID.
The domain to use to authenticate the user when connecting to the controller. This can be left blank if the user to be authenticated has been defined on the ADS controller.
The type of authentication to use when connecting to the ADS controller. This value can be set to either ntlmdomain or Kerberos
