The following table lists all events generated by the OSIM boot server.
Event ID |
Event Meaning |
101 |
Boot Server started |
102 |
Boot Server stopped |
120 |
TFTP: File xxx Source yyy |
301 |
MAIN: Init Error - Failed to establish TCP/IP environment - xxx |
302 |
MAIN: Init Error - Failed to get host information - xxx |
303 |
MAIN: Init Error - Failed to open Configuration section xxx. Error yyy |
304 |
MAIN: Init Error - Failed to read Configuration value xxx. Error yyy |
307 |
MAIN: Init Error - begin thread failed - xxx |
309 |
REP: Init Error - Failed to open FCOR xxx |
310 |
MAIN: Init Error - No valid/active interfaces were found |
702 |
TFTP: File xxx Source yyy Socket Error - zzz |
703 |
TFTP: File xxx Source yyy File open Error - zzz |
708 |
TFTP: File xxx Source yyy Illegal request |
709 |
TFTP: File xxx Source yyy File not found |
710 |
TFTP: File xxx Source yyy No prior BINL request |
803 |
ADS: Query xxx failed. Result code yyy |
804 |
ADS: Failed to get Event Nofication. Result code xxx |
806 |
ADS: Lost connection to the ADS provider. Result code xxx |
901 |
Unable to read Configuration value xxx. Error yyy |
