You can use two different methods to create an OS image for VMware ESX on the Image Prepare System and installed from a boot server.
You can create an OS image on the Image Prepare System either with a command-line utility from a command prompt window or by using the DSM Explorer.
This command requires the type (-o option) and the name (-i option) of the OS image to be created. The new introduced types for VMware ESXi are:
createosimage -o VMWARE-ESXi51 -i esxi51
