Previous Topic: DSM Explorer Can Change the Password Values in OS image DefaultsNext Topic: Overflow in Sharing BufferWhen Using DOS Boot Images
OS Installation Cannot Detect NFS Server
Symptom:
OS installation does not detect the NFS server.
Solution:
If the OS installation can not detect the NFS server, the IP address has to be used for the parameter “BootServerNFS” .
The parameter “OSImageNFS” must be set with the NFS share name providing the Linux image on the NFS server.
If the LINUX setup ends with access denied, check the NFS share access rights. ANONYMOUS USER must have read access. Check also the file, directory access rights of the shared files, directories. ANONYMOUS USER must have read access.
