The OS Installation can be part of a DSM group:
You can use this group to change OS installations. You can also create a dynamic group by associating a query to the group. For example, if you want to use a group of computers where the OS image winxp1 is installed, define a query and name it. The query is then assigned to the group. To create a dynamic group, follow these steps:
The new group is added under the Computers and Users node. The new group does not have any computer associated with it.
The new group is associated with the computers resulting from the selected query.
The Edit OS Installation Parameter dialog appears, which lets you edit the selected parameters.
