The parameter created is an Extendable Map List (Type=MapListExt). The item values have a maximum length of 128 bytes (MaxLength=128). When the OSIM OS image is assigned to a target computer, the value of this parameter can be inherited from the scheduled configuration or the current configuration (Trans=yes).
The example contains entries for Chinese Macau, Danish, English US, English UK, and French Standard.
If you did not define special properties of [localeID] in the default.ini, registerosimage will add default properties:
[localeID] Type=Text MaxLength=255 Trans=yes Comment=CAMENU\xxxx
Using this specification, the parameter presents a text field (Type=Text) of size 255 (MaxLength=255). It can also inherit values from predecessor configurations (Trans=yes). The comment specifies the location of the file where the parameter has first been detected.
Note: Do not omit the dollar characters ($) before and after the parameter name. They are mandatory.
