Previous Topic: Install OSIMNext Topic: TFTP and Share Access
Disable or Enable the Boot Server Process
When you install a Client Automation domain manager or scalability server, OSIM boot server is also installed by default on the same computer. If you do not want the computer to act as a boot server, you can disable the boot server process. You can enable the same when required.
Note: The command must be executed at the boot server.
