You can see the created and registered images in the All Software folder in the Software Package Library.
All images created and registered at the Image Prepare System are displayed in the All Boot and OS Images sub-folder of the Software folder.
When you select an image, all of its parameters are displayed. If applicable, you can edit the default values or reset them to their default settings.
You can change or reset the default values with the DSM Explorer as long as the image is not assigned to a target computer.
