The IPS has a set of OS image templates. These templates can be viewed using the CreateOSImage command. All available images are defined in the Template.ini, which controls the CreateOSImage command.
You should be familiar with the process of creating new image types and installation templates before you attempt to create them.
You can add a new image type by adding a [ostype] section including the keys for specification. See the key descriptions following.
Template files in the os-template\camenu\<ostype>.xx and in the os-template\images\<ostype> also belong to an OS type. The assignment is defined in the template.ini file.
For more information, see Template.ini.
