The RegisterOSImage command provides an option to overwrite the default values of the parameters in the database. For the overwrite operation to be successful, you must set the UpdateDefault attribute of the parameter to Yes; Otherwise, the default value are not overwritten. The following RegisterOS command overwrites the default values:
RegisterOSImage -i <image_name> -s <manager> -e [-b]
