Previous Topic: GETIMAGE64Next Topic: Backup Policy
(Optional) Backup your model PC (Step 2)
The process of prepare (sysprep Step3) modifies the OS installation on the model computer such that it cannot reboot into the operating system anymore. You can back up the model computer so that you can restore the same and boot into the operating system after you have captured the image.
To backup an image, you must run an OSIM backup job that captures the OS image using the specified imaging tool.
To create OSIM install jobs to back up an image:
  1. Create an OS installation job for the model computer in DSM Explorer.
  2. Set the value of following OS installation parameters:
Parameter
Description
OSImage
Specify "getimg" or "getwepos" depending on the support OS type.
BootSpecial
Specify the required boot image.
ImagexImage
Specify the name of the image file to create.
CreateImage
Specify "backupImageX" or "backupGhost"
BackupPolicy
Specify the backup policy for the job.
  1. Activate the job (use Wake-On-LAN for automatic boot).
    The following events occur:
    The following screenshot shows the location of the new image:
    Location of the new image
    Note: If the C: partition does not exist on the model computer, the getimage.cmd command terminates after writing to the error to the log file.
    For Ghost32, the directory contains the ghost.exe file and the file <$imageXImage$>.gho will be created by getimage.cmd.
  2. Finally the model computer shuts down and the OSIM job status in DSM Explorer is set to Stop.
