The language identifier specifies the code page to use during the operating system setup. Valid values are as follows:
Chinese (PRC, Singapore)
Chinese (Taiwan, Hong Kong SAR, PRC)
Latin (North America, Western Europe). This is the default value.
Hebrew
Japanese
Korean
East European (Romania, Hungary, Poland, Slovakia, Czech Rep.)
Thai
A WinPE-based OS image has its own disk partition file named <imagename>.wp1 in Microsoft diskpart format. The disk partition file is created in the camenu directory of the image store. You can specify which disk partition to use, for installing the OS image on the target computer.
To define the disk partition for WinPE-based OS installations
An OS Installation job is created under All Computers, {Group Details}, OS Installations.
OS installation parameters appear in the right pane.
The Edit OS Installation Parameter dialog opens.
Creates only one active primary c: partition on disk 0 of the target computer.
Creates the hard disk partitions as defined in the .wp1 file.
When OS installation job executes at the target computer, the operating system is installed on the disk partition you specified in the WinPEParitition parameter.
Note: If the boot parameter "CreateNewPartitions" is set to true , OSIM ignores the SANID boot parameter because it uses the existing available partition (C drive) created by previous windows installation for new OS Installation. Supplying boot parameter SANID with boot parameter "WinPEPartition" with value "Use special partition file W2012.wp1 from CAMENU", forces OSIM to ignore parameter "WinPEPartition" value. If SANID is specified, OSIM identifies the disk needed to be used for OS installation and ignores the supplied external partition file for OS deployment.
