Defines the features or properties of the OS image. The value of this property can contain a comma-separated list of key words.
Note: The key words are case-sensitive.
Following tables provides the list of key words that you can use with this parameter:
Keyword |
Definition |
F140-2 |
Specifies that the image can accept parameters in FIPS-compliant encryption only |
DosTftp |
Specifies that the image supports installation using a DOS-based boot image in TFTP mode. |
DosLm |
Specifies that the image supports installation using a DOS-based boot image in share mode. |
PeTftp |
Specifies that the image supports installation using a WinPE-based boot image in TFTP mode. |
PeLm |
Specifies that the image supports installation using a WinPE-based boot image in share mode |
Pe2Lm |
Specifies that the image supports installation using a WinPE20-based or WinPE30-based boot image in share mode |
Pe64Tftp |
Specifies that the image supports installation using a WinPEx64-based boot image in TFTP mode. |
Pe64Lm |
Specifies that the image supports installation using a WinPEx64-based boot image in share mode |
DosLmT |
Specifies that the image supports Linux-based boot image using TFTP in share mode. |
