You must add additional drivers to Windows Embedded POS images manually, because IPS does not add them to the image automatically at the time of creating the image.
To add additional drivers to Windows Embedded POS images
Note: The detailed definition of driverinstall.xml schema is available in the Windows Embedded POS documentation.
The following snippet shows a sample driver description:
<?xml version="1.0" encoding="utf-8" ?>
<Drivers>
<AdditionalDevice ClassId="{4d36e972-e325-11ce-bfc1-08002be10318}" SourceDir="\D2DriverFiles">
<!-- "Broadcom, NTx86.5.1, NTamd64" -->
<File Name="b57win32.inf" InstallDir="inf" />
<File Name="b57xp32.sys" InstallDir="system32\drivers" />
<HardwareId Id="PCI\VEN_14e4&DEV_1677&SUBSYS_01AD1028&REV_01" />
</AdditionalDevice>
</Drivers>
The additional drivers are added to the image. These drivers will be installed on the target computers when the image is applied.
