By default, a Continuous Discovery agent discovers and monitors any newly discovered subnet (added to the MDB by Classic Discovery). You can configure a Discovery Agent to discover and monitor additional subnets by assigning subnets to each agent manually. Workload balancing can be enabled or disabled on the Discovery Manager when you add additional subnets using this method.
Note: You can also discover only a subnet using the dscvrbe command and workload balancing. After the subnet is added to the MDB, workload balancing assigns the subnet to an available agent and the subnet is then monitored by the agent. For more information about the dscvrbe command, see the online CA Reference.
To manually add subnets to a Discovery Agent
The Properties notebook for the agent appears.
The RunTime page appears.
Separate subnets with commas. You can use wildcards to specify subnets. You can also define a range of subnets by separating the range with a hyphen (-). Only one range of IP addresses per subnet is permitted.
Additional subnets to manage are defined.
The Properties notebook appears in the right pane.
Workload Balancing is enabled.
The additional subnets will now be discovered and monitored.
Example: Valid Subnet Filters
Valid subnet filters are as follows:
xxx.xxx.xxx.xxx where xxx is a valid number between 1-254.
*.*.*.* specifies that any subnet should be monitored by the agent.
xxx.xxx.xxx.* specifies that all subnets of xxx.xxx.xxx should be monitored by the agent.
xxx.xxx.xxx.xxx - xxx.xxx.xxx.yyy specifies a range of IP addresses in a subnet that the agent should monitor.
To specify that a range of IP addresses for three subnets should be monitored, use an entry similar to the following entry:
172.16.333.0 - 172.16.333.128, 172.16.334.1 - 172.16.334.128, 172.16.335.1 - 172.16.335.128
Copyright © 2010 CA.
