This section contains the following topics:
Configure the DIA Communications Port
CA NSM employs the following primary data transport mechanisms to transfer data between CA NSM enabled nodes:
Other legacy communications mechanisms may also be supported by CA NSM for the purposes of backwards compatibility.
To support these communication mechanisms, certain ports in a firewall must be open.
Note: CA is committed to reducing the number of ports that are required to use CA NSM. For this reason, we have identified the ports that are required and the ports that are optional. CA Technology Services can help you design the best port solution for your enterprise.
This table provides a list of the ports that are required to be open in a firewall to support basic communication among CA NSM components.
Component |
Default Port |
Port Type |
Install checks if default port is in use? |
Install prompts for different port if conflict exists? |
Comments |
CA Common Communications Interface (CAICCI) |
1721 |
TCP |
Y |
Y |
CA IANA registered CAICCI listener port (CCI Remote Service). |
CAM |
4104 |
UDP |
Y |
Y |
Used for System Performance, Continuous Discovery. |
DIA |
5635 |
TCP |
N |
N |
Used for MCC to Manager communication |
DIA |
5636 |
TCP |
N |
N |
7001 |
TCP |
Y |
Y |
Required for NSM communications that use CCI between Windows servers. |
Apache Tomcat |
9090 |
TCP |
Y |
N |
Services incoming requests by component applications that expose functionality through Tomcat, such as Unicenter Web Reporting Server. |
Apache Tomcat |
9005 |
TCP |
Y |
N |
Used when Tomcat waits for a shutdown command. |
DIA |
11501 |
TCP |
N |
N |
Only requires firewall to open outbound |
DIA |
11502 |
TCP |
N |
N |
DIA |
11503 |
TCP |
N |
N |
DIA |
11504 |
TCP |
N |
N |
Used by DIA for manager to manager communication |
Ingres Remote Client |
19016 |
TCP |
Y |
Y |
Used to communicate with MDB server if you are using an Ingres database. Port number is bound to Ingres instance name. Default code is EI, but can be changed at installation. |
This table provides a list of the optional ports that are required to be open in a firewall to support only certain low-level features or compatibility with a previous version. These ports are grouped by their specific component in the Ports by Component section.
Component |
Default Port |
Port Type |
Comments |
Non-CA agents, Enterprise Management |
162 |
UDP |
N |
N |
Native SNMP traps sent to DSM policy. Required to receive traps from non-CA agents. Additionally, Enterprise Management requires this port if Trapmux is used to support SNMP V3. |
CAM |
4105 |
TCP |
Y |
Y |
Used for System Performance, Continuous Discovery, CAM. This port needs to be opened in a firewall only if the CAM communications method is set to TCP. Default mode of operation among computers is UDP. |
6161 |
UDP |
N |
Y |
When trapmux is active, used as the catrapd command port. |
6163 |
UDP |
N |
Y |
If Trapmux is being used (SNMP v3 support is activated), catrapd opens this port on which to listen |
Agent Technology |
6665 |
UDP |
N |
N |
Used only if DIA is not installed |
Mobile Services |
8888 |
TCP |
N |
N |
Used for communications between a CA NSM manager and Pocket PC devices. Disabled by default. If Pocket PC connectivity is required, Mobile Services must be activated and this port opened. |
7000 |
TCP |
N |
N |
Default for AP/OPS interface component. Configurable at site. In field since 2000. Is not required if all nodes are at r11 or higher. |
Agent Technology |
7774 |
TCP |
N |
N |
Required when using Agent Technology processes using the -@ option. |
Copyright © 2010 CA.
