Previous Topic: View User PermissionsNext Topic: Effective Remote Control Permissions Dialog
Select User Dialog
Use the Select User dialog to select a user for whom you want to view effective remote control permissions.
This dialog contains the following fields:
Select a Security Authority and Browse for Principals
Displays the available security authorities. Select an authority from the directories tree and browse for principals.
Security Principal Properties
The following fields specify the security principal properties:
Container Identifier
Displays the container identifier of the item selected in the directories tree.
Names
Lets you use the Add button to select security principals and add them to the Names list.
Description
Identifies the user or group account selected as a security principal.
List of Security Principals
Lists all security principals whose permissions are about to be added to the address book group.
This dialog contains the following buttons:
Add
Adds selected users to the list of security principals.
Remove
Removes a selected security principal from the list.
OK
Invokes the Effective Remote Control Permissions dialog.
