To deploy a new software policy, follow the wizard's instructions!
The Create Software Policy wizard assists you in doing the following:
Before you finish you can select the "Distribute and register software packages at the domains" box and the "Open the advanced software policy settings dialog when the Finish button is pressed" box.
