Provides the degree of automation for the software policy.
Degree of automation
Select one of the following alternatives:
Select this option to make a conformance check for all members in the group. If any non-conforming members are found, they are added to the Violators folder.
Select this option to make a conformance check for all members in the group and to set up, but not activate, jobs for members not conforming to the policy conditions. The job container containing the jobs is not sealed.
Select this option to make a conformance check for all members in the group, and to set up, as well as activate, jobs for members not conforming to the template conditions. The job container containing the jobs is sealed and the jobs will execute at the specified time.
You may also check the following options:
