Use the Browse button to open the Explorer to select the path to the SXP package directory.
The directory should contain files with extension sxp.
Response files are not especially catered for.
Select directory in the Choose Directory dialog:
To start copying, select "Choose". The file(s) in the selected directory will be copied, and the item will be registered in the library with its procedures.
SXP packages are created on Windows packaging computers.
