Displays job-specific information.
By default, a concatenation of the name of the software item and the procedure, selected for setting up the job.
The name of the software item selected for setting up the job.
The procedure to be used for the job. In a scroll box, you can select among the procedures - of the appropriate task type - defined for the current software item.
When you choose "Junction" from the drop-down list, more dialog boxes may open.
The install procedure to be referred to for the job, when the task type is not "install". In a scroll box, you can select among the install procedures that are defined for the current software item. The box can also contain an asterisk (*), which refers to any of the installations made on the computer.
Check this box, if you want the evaluation of the current assigned job's potential targets to be repeated for every evaluation of this group.
Note: The software policy job property Repeat for every evaluation has no effect on ad-hoc software policy evaluation. Ad-hoc evaluation never performs repetition of non installation jobs. This property only has an effect during scheduled evaluation of software policies.
Click this check box, if you want to use this feature which forces a re-installation of the software.
Note: For more information, see the Software Delivery Administration Guide.
Defines the custom administrator message text to display to the end users.
