Previous Topic: Register / Import Software Package as New VersionNext Topic: Software Package Library Folder
Export Software Package
Copy location
Enter the path where to copy the software package or click Browse button to browse through the explorer.
Target is on manager
Check this box, if you are using an Explorer on another computer than the manager itself and you want to give the path to a local drive on the manager.
