Previous Topic: Embedded FileNext Topic: External File
Added File(s)
Detailed information about the software procedure.
File path
Specifies the name of the file that is called when the procedure is executed. The file name should not contain the dollar sign ($).The procedure can consist of several files containing the instructions to be executed when the procedure is called.
Source path
Specifies the full path, excluding the file name, to the item procedure body. This is automatically determined when the added program has been selected. For example, if the item procedure only consists of one file called item1.exe, which is located on the C: hard disk drive in subdirectory subdir1\subdir2, then the source path will be C:\subdir1\subdir2\ (and the program path item1.exe).
Source is on Manager
Check this box, if you are using the Client Automation Explorer on another computer than the domain manager itself and you want to give the path to a local drive on the domain manager (as seen by the manager). Otherwise, do not check the box. If this box is checked, the Browse button is grayed out.
Note: If you use this option, you cannot use UNC paths: You have to manually map a drive at the manager to the actual location and use that path instead. For example, if the UNC path is \\Server\share\dir, map x: to \\Server\share and then use the path x:\dir instead of the UNC path.
Type
Specifies the type of file.
Parameters
Additional values that are used as input to a procedure when that procedure is executed. These parameters are entered and used as any command-line parameters. Use a space to separate the parameters.
More Information:
Procedure Parameters
