Previous Topic: Copy VolumeNext Topic: Copy Next Volume
Copy Error
You are using a software delivery function that involves the copying of files to the Software Package Library. The copy process is to handle the next file, or directory, but does not find it, or cannot access it.
You will encounter a dialog, where you have the option of continuing with the other files (Ignore button), thus bypassing the missing file or subdirectory, or canceling the process (Abort button).
If you click the help button, the online Message Guide will display the message referred to in the dialog, with reason and action.
