By default, delivering software to targets that already have the software installed will mark the job as failed. By setting the following flag, the job status "already installed" will not be regarded as a failure.
Max job time out: 7 days 0 hours.
You can configure jobs to time out if they have not started their execution within a certain time period. The following parameters set a limit to the range of possible time -out values defined when a job is set up.
Jobs using scalability servers will implicitly deliver software from the manager if not present in the scalability server's staging library. To maintain a better control of the deliveries in the network, you can turn off implicit deliveries. If turned off, jobs will fail if the required software is not present in the staging library.
Note: This option is only available for NOS agents. For DTS agents there is a different policy, Fail implicit DTS agent deliveries. For more information, see Manager Policy Group
During the evaluation of a job container, software delivery can cross-check against all Software Policies to ensure no policies are violated. Any attempt to uninstall a software package that is assigned to be installed via a policy is denied. Any attempt to install a software package that is assigned to be uninstalled via a policy is also denied. In addition, for Software Management packages, any attempt to install a previous delta version is denied.
