Information about a sealed and operational software policy is provided, such as jobs that have been assigned to this policy, and targets that are not conforming with this policy (violators).
You can view additional information about the policy in the Details box, and by selecting the Show properties task.
Select one of the following actions:
Use this command to seal a job container, set up and activate the jobs in the container.
The same state of a job container will be reached by selecting the Set up and activate jobs for members not conforming to the software policy options.
To change the state of a sealed software item, select the item, right-click and select Unseal on the context menu.
When you have executed the command, the software item will be unsealed and disabled and can be edited.
Use this command to break up the link previously set up between the Software Policy and the Asset Group.
