If you select the Procedure Group folder, when it has been user created in the Software Library folder, you will see all the members of the group in the right pane.
All types of procedures are valid for inclusion in this folder.
If you select an item in the folder, a context menu appears with the choices:
The individual procedures in the folder can be moved around (up, down, to the top or bottom) to change the order in which they will be executed by software delivery.
