If you select the Software Package Library folder and expand it, you will at first not detect any Procedure group folder.
You will have to create such a folder by selecting Library, right-clicking and choosing New, Procedure group in the context menu. Then, using copy and paste, or drag-and-drop, you have to populate the folder.
All types of procedures are valid for inclusion in this folder.
If you now select the Procedure Group folder, you will see the procedures that are members of this group in the right pane.
If there are any procedures in the folder, they are listed with three characteristics, in columns, in the right pane. These are
The name of the procedure
The library item to which the current procedure belongs
A number which denotes the order in which the procedures should be executed.
If you select the folder, a context menu appears with the choice:
If you drag and drop onto the Procedure group folder, a context menu appears with the choice:
